Scaner for ar235
+ More Options
Posts
  • adel_nagieb2000@yahoo.com
    • Jun 2009
    • 14
    Scaner for ar235
    Please someone help me
    i need oprate the scanner of ar235
    by scanner key
  • bilyahn
    • Dec 2006
    • 1470
    You will need to install Sharpdesk for this. It comes with the install software. Once you have that installed then you can scan. That is the easiest way. You can go to the machines web page and put in an ip address for your destination but that is way more involved and full of irritating problems.
    Good luck.
    Bil
    • KyoceraChris
      • Jun 2009
      • 112
      i think he need the product key to enable the function.. i would help if i could but we dont sell those anymore
      you gunna eat yo corn bread?!?
      • Wynard
        Used to be a Tech
        • 42
        Actually, the sharpdesk-code is very simple... know the first 10 letters (always the same), add the rest randomly in a certain pattern and you got your key
        However, to enable the scanning function he needs the scanner kit which needs a key obtained from Sharp Japan to function... different story. What exactly do you need?
        Since the creation of the internet, the rotation of Earth has been powered by English teachers spinning in their graves.
        • efe311
          • Oct 2008
          • 114
          try the scanner demo key its zero just one zero "0" in sim 26-10 but if u rebeat it u well lock the scanner option
          • lky1978
            • Mar 2009
            • 482
            Before you enable network scanner function, you need add extra sd ram at least 32mb .if not simulation 26-10 does not exist for trial mode .
