sharp ar336 error l4-01
  • mikepmcs
    I am getting an error on a sharp ar336 copy machine. it is error l4-01. couls somebody please let me know what this error is for.
    thank you
  • davidhackler
    L4-01 Code
    L4-01 code is Main Motor lock detection (Toner Motor)... Check with Sim25-1
    • choicecopyguy
      • Mar 2006
      • 111
      Pull the fusing unit and see how "tight" it is. bad bearings will cause this.
      • mikepmcs
        sorry guys i am fairly new to this. what is sim25-1
        • davidhackler
          sim 25-1
          press the following buttons in this order: program,interrupt,clear,interrupt. That will send you into the diag. mode... the press 25 enter that will get you into sim 25 then press 1 that will send you to the main motor test then press execute on the screen to turn on the main motor.
          SIM 25-1
          "Used to check the operation of the main drive (excluding the scanner section) and to check the operation of the toner concentration sensor. (The toner concentration sensor can be monitored)" *the following was directly from the sharp service man.*
          • clint47
            main motor lockup
