AR-286 will not start
  • oldschool
    • Mar 2007
    • 245
    Hello all
    I have been out of copiers for a few years. I m trained on older Canons, Minoltas and Savins. I now work at a company that designs vending interfaces for all makes and models. We have a Sharp AR-286 that was working fine yesterday. This morning when I turned it on it never went past the boot screen. It just sits there with the animated Sharp logo just spinning. The display never comes active and all I hear are fans. Anyone have any thoughts.
    Jamex Tech Support: Saving the world one phone call at a time.
  • JustManuals
    • Jan 2006
    • 9838
    Im not a copier tech, but when a similar situation happens on a printer, it's usually caused by bad memory. In you case it may be the memory of if the copier has a hard drive, that may be the problem.
    HtH
    paul@justmanuals.com
    • choicecopyguy
      • Mar 2006
      • 111
      Check the HD with sim 62-3 if this comes up NG, try reformating with 63-1. If this does not work, replace.
      • oldschool
        • Mar 2007
        • 245
        I cant get into any sims copier never gets far enough to let me get to op panel functions.
        • davidhackler
          Bootup
          Sharp calls it "spinning Stars".... Replace the hard drive, per sharpnet
          • oldschool
            • Mar 2007
            • 245
            That was the problem!!
            Thanks!!!
            • Jim Tanis
              Sorry, hit wrong key. I'm a newbie!!!!!!!
