AR-M280 Clear display message
  • vintech
    • Jul 2025
    On the AR-M280 copier , how do you get into service mode to clear the required maintenance message on the display?
    Please
  • Andyrsv
    • Jun 2008
    • 59
    P*C* 24 then select the item you wish to clear
    • Dark Helmet
      • May 2009
      • 845
      Make sure your in copy mode when entering that key sequence and if you just replaced the drum make sure you clear the 24-11 Drum counter timer and if you did DV make sure you enter 25-2 before closing the door then run the DV calibration.
