Is there a place that the crum chips; that are used on some toner cartridges; can be sent off to be reset or a place to purchase new chips???
Thanks!!!
Katun doesn't carry them and I did take the one off the existing cartridge but found out that they only have a certain life before they will stop working. My problem was not realizing that the toner cartridge for a Sharp ARM 350 would not work in an Imagistics IM-3510 though they are the same copier.
In crum chips For each model certain identification values are entered.
For Sharp 350 these values differ from Imagistics IM-3510, other same data. For change of the identifier of an accessory to model of the device and change of a regional code, it is necessary special “Chip Recharge device” for crum chips. It concerns crum chips manufactures sharp till 2006. Crum chips, let out later and Crum chips – manufactures Katun, it is impossible to reprogram.
Excuse for bad English
