Sharp AL1530CS
  • micko
    • Jan 2007
    • 17
    Sharp AL1530CS
    Have customer with this machine - when print button is pressed optics carriage moves slightly with lamp on, stops then blank copy is exited from copier. No error codes apparent. Any thoughts? Cheers Micko
  • BODINE
    BODINE
    • Mar 2005
    • 74
    Make sure scanner lock is off and the rails are clean
    • davidhackler
      Sharp AL Machine
      I have seen other techs get the cover screws mixed up and used the longer screws on the top of the back cover and they are long enough to block the scanner, just a thought
