We have an AR-FN15 Finisher that is on a MX-700U. When using the stapler option, more often than not, the stapler sometimes fails to staple multiple sheets together. It seems to misalign some of the pages so that the staple goes through some of the pages but not all. On occasion, I do not hear the stapler attempt a staple operation.
Sharp Technical support suggested that I look at the paper feed sensors on the LCC.
I informed the tech that it happened on all cassettes. He then suggested checking ground to neutral, which by the way is less than 1/2 volt. We also have a Sharp power filter on this machine.
This looks like a mechanical issue to me. I also inspected the parts suggested on the old SharpNet site pertaining to worn "Stoppers". They appear in good order and do not seem to stick. This machine is in a high school, high volume area. Sharp IDNC shows nothing pertaining to this problem.
Thank you in advance for any suggestions.
Ray
Ray
