plz,help me abt Sharp 5320?
  • ifback
    • Feb 2006
    • 52
    i have some with problem abt it,
    light on with these icon of body, toner, *.,on panel.
    i dont know what is it,
    plz help me.
    I'm technical of Toshiba.so i really yr helps.
    if bro have Service manual of it,Sharp 5320,plz send me.
    i will send back 4 u abt Toshiba.OK?
    thank a lot.
    my mail chaoyork@yahoo.com
  • Copier Systems
    Sharp-5320
    Are you sure you are working with a sharp-5320. what area are you located.Is it a sf or ar series Worked on sharp for 15yrs that # does not ring a bell unless its a seg 1 unit which i dont work on. when you say 5320 i can only think of xerox-Tosh
    Re -ck model dont think that unit is in the us market under that number but i dont know everything could be missing something.
    Andy h.
    • Copier Systems
      Sharp 5320
      That problem you were describing is either the toner wast bottle which is located to the right of the paper trays depending on the configuration 25-40 copies per minute 50cpm and up will be on right door area is the symbol
      a cup with toner dots in it? If so try the above.
      AndyH. Worked in Canada and the old savin machines were marketed under the Natusha name before natusha an Savin parted company,an Savin entered the Canadian market. Oh to be young I thought Liquid Toner Was the future of copying sold tons of those boxes,many yrs. ago
      I wonder whare are they now.
      Andy H
      • ifback
        • Feb 2006
        • 52
        thank you,AndyH
        i come from VietNam.
        Yeah.I'm a Toshiba Technician.i really confused when i met Sharp Ar 5320. this problem i solved.
        next time,maybe i need yr helps.
        thank a lot
        Welcome to VietNam....
        • copi_40
          • Mar 2006
          • 49
          Sharp AR (5316) 5320 (non available in America).Base machine is AR-M (160) 205.
          Use Toshiba E-161 service manuals ,is the same machine.Caution !!! Sharp`s have chips on toner cartridge (Toshiba`s no) !
          • JustManuals
            • Jan 2006
            • 9838
            I have the service and parts manuals for the 5316-5320 on my site at Just Manuals
            Paul@justmanuals.com
            • ifback
              • Feb 2006
              • 52
              thank you copi_40.
              thank a lot.this problem i solved.
              • mainakarundi
                toner
                The triangular dots indicates toner is over.
                If its blinking then you have to replace it.
                Hope it works
