sharp ar-507 h5-01 code?
+ More Options
Posts
  • jrex
    can someone tell me how to clear it? thanks
  • arriva1
    • Apr 2007
    • 66
    program interupt clear interupt 14 start start that will reset it after the problem is corrected
    • davidhackler
      H5-01
      H5-01 code is set when there are 3 continuous jams at the pod1 sensor... usually there will be paper wrapped up around the fuser roller(s)... Check fuser and reset code....sometimes low fuser heat will cause the jams in the first place...make sure the thermistors are clean and that the heat lamps are in good working order
      • fireater
        Repair God? not quite
        • Apr 2006
        • 253
        prolly time for new UHR and separator fingers.. or if there is a finisher make sure the exit rollers are working right and the springs are off.
        I fix copiers ...Well Sorta
        • DavidEtling
          • Feb 2005
          • 31
          ar-507
          Also make sure the picker fingers aren't broken, will cause continual paper jams.
          • digital copier resources
            The B
            • Apr 2006
            • 10
            It is definitely a fuser problem, most definitely, very sparkly looks like a holiday definitely
