E7-13 sharp ar5132
+ More Options
Posts
  • bomberi
    • 107
    E7-13 sharp ar5132
    Hello, i have a problem with a sharp ar 5132. The error is E7-13. Can someone help me to fix this error?
  • vlad_robas
    • Oct 2006
    • 225
    E7 13 Content CCD light amount check error
    Detail Copy lamp light amount adjustment in
    shading cannot be made
    Cause
    Copy lamp does not light (broken wire,
    improper installation)
    Copy lamp light amount is more than "46"
    of SIM5-3.
    Improper installation of flat cable to CCD
    unit
    Improper connection of copy lamp CL lead
    wire
    Mirror, lens, or reference white plate
    Dirt or dew
    Improper output of copy lamp power supply
    Improper installation of CCD unit
    CCD unit error
    ICU PWB error
    Check and remedy
    Clean mirror, lens, reference white plate.
    Check copy lamp for light amount (SIM5-5)
    and lighting.
    Check CCD unit.
    Check ICU PWB.
    • bomberi
      • 107
      thank you for answering, i have done all thise action and the error always appear. I think that the error is the laser or hdd I want to now if is possible to solve the error? GOOD
