Pdf printing issues
  • Dustin(WOP)
    • 223
    Pdf printing issues
    Hello again
    i am having some printing issues with an mx-4101n. When the try to print pdf documents in landscape all the pages will print landscape except one page. And it is never the same page in the document that print portrait. This is a weird issue that i have never ran into before. If anyone has any suggestions on what to try.... I would really appreciate it. Thanks.
  • OMD-227
    Make sure that 'Print as image' is selected in the Acrobat Advanced Settings if you are using acrobat version 8 or above.
    • Dustin(WOP)
      • 223
      Tried this it did not work, any other ideas??
      ALSO WHAT I HAVE NOTICED IS THAT THE DOCUMENT PRINTS AS IT IS LAYED OUT. AND NOW THE DOCUMENT ALWAYS PRINTS THIS WAY TO ANY PRINTER THEY HAVE WHEN IT WAS PRINTING CORRECTLY BEFORE SHARP SOFTWARE WAS INSTALLED....ANY CLUE AS TO WHAT IS HAPPENING?? THANKS
      • OMD-227
        Does your machine have PS installed?
        if so, print it via the USB port as this will avoid the driver and program.
        Also try a different version of acrobat, as it definitely sounds like a program/document template problem, not a problem with the machine.
        • ExOceMan
          • Sep 2009
          • 63
          Are you using the Auto Rotate and Center selection in the print driver? Also have you looked to see if the sheet is the same size as the other pages that print in the correct orientation?
