AR310 DRUM
  • gwaddle
    • May 2009
    • 782
    AR310 DRUM
    Does anybody know if an AR310 drum can be substituted for an AR271. Ran out of 271s. Thanks. By the way this is going in an ARM237
    I know I should be ashamed of myself. Strangely though, I am not.
  • Dark Helmet
    • May 2009
    • 868
    Ive never tried it but the OPC on the drums looks differnt. The front frame collars look differnt to. look at the pic.
    I'd be curious to know if the AR310DU will work with a 237/257. Im told i can't order the frames from supplies any more as they stopped stocking the older versions.
    • gwaddle
      • May 2009
      • 782
      Thanks for the response Lawrence. I tried anyway and the problem that really keeps it from working is the size of the hole in the front. It's too small for the locking shaft to go in. Other than that I think it would work.
      • Johsel
        • Mar 2009
        • 9
        Hey dude what our problem here in the philippines is we ran out of 310dr, one of my of my co engineer tried to use ar271dr but it did not fit. Maybe we can exchange???
        • gwaddle
          • May 2009
          • 782
          I'll be right there to get it.
          • Dark Helmet
            • May 2009
            • 868
            what would happen if you put a 257 drum pin in the 237 frame?
            • gwaddle
              • May 2009
              • 782
              I thought about that but I didn't have one to try. I'm going to check that out.
              • irtek
                • Jun 2009
                • 113
                Another thing you could do is put the drums in a freezer for an hour or two then you can pop the plastic end out of the drums and swap it.
