ar-m45on wats drive?
  • DINGO
    • 661
    Hy friends
    Y want yours opinion about, wat is the better drive for a ar-450n for print fast pdf documents and word.
    pcl5, pcl6, ppd, ps and so.
    another mater, is possible to print directly of the web page whithout open the documents??
    thanks for take yours time.
    regards
  • bilyahn
    • Dec 2006
    • 1470
    PS or Postscript if the best for PDF files but it costs additional to get the ARPK1N(?) so I have used the PCL6 driver for the most part. Have had some issues depending on the version of Adobe Reader that the user has.
    Hope this is helpful.
    Bil
    • DINGO
      • 661
      re
      Ok, but pcl6 i`snt more fast them PS?
      thanks
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Keep in mind that while PCL may (or may not) print office documents a bit faster, a PDF file is already a PostScript file, with a little more info.
        Because a PDF is "print ready", it normally processes much faster using PostScript. That's why most PostScript printers allow you to send a PDF file directly to them, without using a driver.
        • DINGO
          • 661
          re
          Ok
          thanks again.
          Do you now something about this copiers print directy using the the browser web?
          regards.,
          • DINGO
            • 661
            re
            One thing more
            and about port configuration??
            raw or lpr?
            by
            • bilyahn
              • Dec 2006
              • 1470
              LPR with a Que name of lp (lower case). If you have Vista or Windows 7 the Sharp drivers are included in the OS.
              • DINGO
                • 661
                ok
                Ok
                thanks, y apreciate very much your opinion, but about the dives y can,t found it, because y use the windwos 7 and a sharp arm-450, y use the vista drives.
                where y can found drives for wind.7 for this copiers?
                regards
                • bilyahn
                  • Dec 2006
                  • 1470
                  Originally posted by DINGO
                  Ok
                  regards
                  I just checked on the IDNC service website and it does not show any specific drivers for Windows 7, yet. If you go into the installed print drivers in the operating system when you go to install the copier itself there should be a Sharp default driver there. At least there is one in Vista so I am assuming there will be one in 7 as well.
                  Good luck.
                  Bil
                  • DINGO
                    • 661
                    re
                    Hello
                    I am using the vista drive, but today y do a experience with the PS drive for w7 of the ar - m550n, and at now works
                    in the ar-m450, he he he, y will see.
                    stay weel, regards
