Sharp SF-2025 flashing AE
+ More Options
Posts
  • BlueCopy
    • Jun 2007
    • 37
    Have an old Sharp SF 2025 that is blinking the code AE and the auto exposure setting light is blinking as well. The light bar is also not coming on. I changed the bulb and replaced the white coated fuse on the light bar with no change. Any suggestions would help, did not find the AE code in the service manual.
  • bilyahn
    • Dec 2006
    • 1470
    Check sim 44-2 and 3 and make sure they are correct. You can adjust them from the front of the drum assembly if needed.
    Good luck.
    Bil
    Misread your post. Sorry the comment I made will not help.
    • Johsel
      • Mar 2009
      • 9
      AE has something to do with AE sensor trouble, you must check first whether the exposure lamp does lit up upon machine warm up. you check also check this function by sim 5 sub 3. you must also check the physical appearance of the lamp. you must also cleaned AE sensor it can be found on the black box near lens. also dont forget to clean all 6 mirror and lenses and clean also IDS and DMS sensor. I hope all of this will solve your problem. Good Luck.
      • DavePo
        • Jul 2008
        • 303
        I have seen this happen when drum count doesn't get reset after maint. The drum wear correction gets way out of wack and cant get copy quality correct. Try resetting drum count and do the 44-02 44-03 adjust.
