DX-C310
  • tweek65
    DX-C310
    Anyone have these out there?Problem text wont fuse to the envlope.Max fuser temp.Can still wipe it off.Its going thru the bypass tray.set for envlope.
  • NCArt
    Mountain Tech
    • May 2008
    • 81
    You have to replace the pressure springs in the fuser. The spring part number and proceedures is on Sharp IDNC-Service.
    • OMD-227
      NCArt is correct. There are new pressure springs to correct the envelope fusing issue.
      However...................... There is a temp change which can help, but may not fix the issue, without changing the pressure springs. So it may be worth a shot to try this first.
      We have done it successfully with one machine in the field, using the original fuser unit.
      Sim 43-01.
      Item S, original 200, new value 205.
      Item T, leave as 140
      Item U, original 220, new value 200.
      This modification is only valid when using a recommended envelope type/size, such as Monarch, Com10, DL or C5.
      If you still have issues, change the pressure springs. These new springs also fix the envelope creasing.
