another sharp 450/imagistic 4510 problem
  • jpcopy
    • Apr 2006
    • 256
    Problem: When feeding out of the large capacity drawer, the left-side (primary) tray jams when the paper is only about half-way through the feed/sep tires. When you remove the paper from the jam access panel, it is not skewed nor bent. The paper just stops about 1 second after it begins to feed. * The right side tray of the large capacity drawer feeds every copy fine. Both left and right trays show paper when loaded and both sides appear to lift properly.
    I've swapped out (from a known good copier): tray lift motors (just to be sure), large capacity drawer main board, the copier's logic board, feed tire clutch from the good side (right side), the entire rear gear assmebly of the large cap. drawer, and the entire large cap. drawer itself.
    any help appreciated
  • choicecopyguy
    • Mar 2006
    • 111
    See my post on TC
