sharp ar-m205
  • ferri
    sharp ar-m205
    hi evrybody
    i have sharp ar-m205 and recently i am not able to scan my documents with it when i scaning with it error code 7 apeared on set and stops working until i power off and on again
    please help me on this problem or give me service manual of this machin
  • Sharpshooter
    • 21
    You have classic problem with your machine and the only thing you need is a firmware upgrade. Call your local Sharp Center and they will help you.
    • ferri
      Originally posted by Sharpshooter
      thank you dear sharpshooter but i have not acces to service center do you have this package
      thanks
      • vlad_
        • 98
        Package firmware, to match the country of use.
        (I hope that this is an error E7-11)
        • ferri
          thanks valad yes it is a E7-11 error code how i can solve it
          • vlad_
            • 98
            You can solve it is updating Firmware. via USB port copier. You need:
            1. Program loader - Maintenance
            2. Special Driver
            3. Itself firmware file xxx.dwl
            The file must match the country of use.
            • bilyahn
              • Dec 2006
              • 1470
              Unfortunately as sharpshooter mentioned the only fixz that I have found for this series is to update the firmware. Pain in the rear but that is the solution.
              Good luck.
              Bil
              • COLLINS
                Re: sharp ar-m205
                2. Special Driver
                hello
                i have the same problem with my sharp AR M205 .... when i try to use the scanner, the AR M205 sign ERROR E7
                how can i resolve it?
                thanks
                bye
                • muhammadislam01
                  • Mar 2011
                  • 1
                  Re: sharp ar-5520/16
                  hi gays *i need firmware software sharp AR 5520/16 copier please help me thank you*
