Sharp AR-337
  • mike1025
    • 10
    Sharp AR-337
    Any help to reset the password for the web access on the Sharp AR-337, thank you
  • bilyahn
    • Dec 2006
    • 1470
    Go into the key operator settings and enable changes to your printer settings. Once these are enabled then you can reset to factory defaults and reset the NIC. If these are not enabled then it will not erase the old passwords.
    Good luck!
