- Hey all I've got a AR208D that's having a recurring E7-10 code (black shading correction). I know it's ccd related and both myself and another tech have checked the ribbon cable. It only happens after it returns to home position and only seems to happen whe the doc feeder is used. It started 1 day after the previous tech went out there and he changed the density settings in 46-1 and 46-2 . Has anyone else run in to this issue before? I've ordered up the grayscale to calibrate it ,it should be in tommorow. The copies and prints are excellent and have great density.
