Sharp MX-2700 and MX-4501 washed out colors
  • TechGeek
    • 158
    I have a MX-2700 and a MX-4501 that the colors are washed out, splotchy kind of like old developer. On both machines i have replaced drum, dev, primary transfer belt did all necessary adjustment reset necessary counters preformed calibration. No changes. the MX-4501 i sold and did the initial setup on and was working fine then but problem started after first PM. The MX-2700 I just picked up service on so i don't know the history. Any ideas would be helpful.
  • Dark Helmet
    • May 2009
    • 861
    Make sure your image density senors are clean and run 44-13 with the jig to recalibrate them. We had a 6200 with extreamly poor solids. We took the sensors out and cleaned them and recalibrated. Solids were perfect after that. Also run your 46-24.
    If your getting "waves" in your solids were they get light and then dark running to the page corners make sure your drums are not worn. When the OPC layer peals off they suck DV out and dump it into the waste toner tank via the transfer belt.
    • TechGeek
      • 158
      Thanks I'll give it a shot and let everyone know.
      • TechGeek
        • 158
        When i took out the sensor it did not look dirty, but i cleaned it any ways reinstalled sensor and recalibrated the machine and everything seems to be working great. Thanks for the heads up.
        • repn1999
          • May 2010
          • 310
          Did you do all of the stuff listed in the calabration tech section on sharpnet? there are steps in that document to correct if the colors arent right. what do your SIM64 print outs look like? are you sure its the copier and not scanner related?
          • TechGeek
            • 158
            Yes i did use the tech bulletin to perform the calibration. My 64 test prints were washed out as well, but after cleaning the image density sensor all worked good.
