Dead Sharp Ar-507
  • T911
    • Jun 2007
    • 628
    Dead Sharp Ar-507
    replaced power supply board and no luck. checked all my door switches and all test good. i have power going in but nothing coming out. what am i missing or is there a bulletin on this one. thanks t
  • Copier Systems
    Sharp-507
    What was your original problem i would assume no power but be a bit more
    Specific about this problem. I HAVE A FEW OF THESE in the field an i will try to help.
    Andy H.
    • T911
      • Jun 2007
      • 628
      machine would turn on and off. then went dead.
      • nightshade
        Chromographic Supremesist
        • 158
        DC Pwb, you need to re-solder all the solder joints for the triacs that are screwed to the aluminum side plate.
