I need to change the IP address on SHARP AR-275
  • sir642002
    • Jul 2025
    I have a problem with Sharp AR-275, I need to change IP address but in manufacturer page didn't find how to change, someone can help me? Thanks
  • ZOOTECH
    Senior member of CRS
    • 3375
    Are you able to access the copier's web page? If so, login as administrator (password Sharp) and change the IP address there. If not able to access web page, then you'll go to Special Funtion, page down to key OP programs (password all 0's) and select Printer. Page down until you find IP Address Settings and there you go.
    • sir642002
      Ok, let me try it
      • sir642002
        Ok, I can access to the copier's web page and configure IP Address. Now I can't install the copier on the computers. I have downloaded software but doesn't work, any advice?
        • bilyahn
          • Dec 2006
          • 1470
          This happens on occasion. You will need to go into the system settings and reset the NIC card, don't recall if you can do this from the web page. It will set the IP address using DHCP then you can go in and change it to what you want after that, either through the web page or system settings. Make sure your gateway settings are correct and your subnet also. You can find the operator's guide for this machine at sharp.ca under manuals, it will give you a step by step procedure to do this, or you can use my method which is to search through ALL of the settings until you find the one you want! LOL They have a very good list of user manuals.
          Good luck.
          Bil
          • sir642002
            Thank you very much ZOOTECH and bilyahn for your help!. Now, I can print and scan...
