hello guys, i am having a really strange problem that i cant seem to put my finger on, a customer of mine has a sharp MX-M450n imager, the wanted to install the print drivers to put the imager on there network, after i got a report that the customer said that when they do a test print they get garbage on the paper, so i decided to investigate the matter, when i got to the customer they said that they did NOT receive any cds with the imager, so they downloaded some drivers off the internet and hoped that it would work. to make a long story short, i downloaded pcl5e and pcl6 drivers from my sharp website, and they did not work i got the same garbage on the paper.i even hooked it directly to a labtop via ethernet cable and no luck.can someone please guide me in the right direction please?
MX-M450N printing garbage
log into m/c as administrator on ops panel. and reset the nic for starters. power the m/c down and leave for a few seconds, then switch on. the nic is now reset to default if that fails remove and clean and memory/dimms with a clean cloth.reseat and give it a whirl. if that lot fails the nic could be spammed.
