Enter Kye Operator Prog Sf-2540/2040
  • KHAN
    • Aug 2006
    • 261
    HI,
    1.HOW CAN I ENTER THE KEY OPERATOR PROGRAM ?
    2. my SF 2540 makes 72000 copies , i put new TONER , each time i trun it ON it runs for some minutes, HOW CAN I ENABLE OR DISABLE THE TONER REPALSHING MODE,
    OR THE DEVELOPER IS TOO OLD AND NEED REPLACEMENT ?
    3. HOW CAN I MAKE COPIES IN THE SIMULATION MODE,
    THANKS NEED HELP ?
  • KHAN
    • Aug 2006
    • 261
    Sharp Sf-2540/2040
    no Body Have The Answer,
    astonishing,funny
    • ZOOTECH
      Senior member of CRS
      • 3374
      1) clear-int-clear...default passcode is all zeros. TC 22-13 will give you the current passcode if if has been changed.
      2) 72k is close to the PM cycle; if it has sat for any length of time, change the DV and do a full PM (drum, MC,etc). Be sure to clear your maint and DV counters and drum and DV adjustment times. Adjust DM and ID sensors to 204.
      3) TC 46-01 adjusts for exposure, several other TCs will give a copy.
      • KHAN
        • Aug 2006
        • 261
        Sharp Sf-2540/2040
        thank You Mr; Zootech For Your Help
        thanks.
