annoying ERROR L4-04 on MX2600N
  • RichH
    #16
    Up to you what you try, when the wiring on the clutch shorts to ground it takes out the 24v. The error code you get will be whatever is using the 24v at the time, it has to be said that so far the main error I have seen is L4-32, but we have also had blank displays and various strange issues. The L4-06 error, I have only seen on the MX41/50 due to the reverse clutch on the lift mechanism.
    • redserv
      • May 2010
      • 307
      #17
      update:guys i had another MXM2600N machine, so i can swap parts to try to get rid of L4-04 error code, i switched the PCU board, black developer motor, and primary transfer unit, still no luck. any ideas????????????
      • OMD-227
        #18
        Can you get the black dev unit out of the other machine too? Try the dev unit and possibly the PF drive unit. These are easy to remove/replace.
        • redserv
          • May 2010
          • 307
          #19
          ok will do i'll try those as well, thanks alot for your feedback
          • Rod...
            • May 2016
            • 11
            #20
            Re: annoying ERROR L4-04 on MX2600N
            I know this is an old thread, but what was your solution please?
