window7 64bit
  • Peter Sim
    • Sep 2008
    • 441
    window7 64bit
    Hai all ,need info and help.
    Can sharpdesk 3.2 support window7 32bit or 64bit?
    Thank in advance
  • bilyahn
    • Dec 2006
    • 1459
    They have a update to version 3.3 for windows 7. You have to install 3.2 to do the update so it would seem that it is supported. Have only installed this on a couple of Windows 7 versions so far and I always update them to 3.3.
    Good luck.
    Bil
    • spotlifter
      • Mar 2008
      • 65
      To install a fresh Sharpdesk on win7, first you need an update sharpdesk version 3.31B and the original cd of sharpdesk version 3.2.
      Version 3.3 alone won't be able to setup (although it works on winxp without rebooting the PC). It will detect "unsupported OS". I have try it.
      To install, run the ver 3.31B and on coming, it will ask to insert the cd of version 3.2 . Good luck!
      sigpic
      • Peter Sim
        • Sep 2008
        • 441
        Thank you Bil and spotlifter.
        • costd
          • Jan 2008
          • 409
          What works for me: first you download (from the Sharp FTP) site the 3.31 version from Mar 10 (it works for 32 and 64 bit versions of XP, Vista, and Win 7 - and has both upgrade and fresh install) Unzip to a file (I like on the desktop). Make sure you read the installation PDF AND uninstall any version of Shapdesk currently on the computer. With the unziped files in a folder on your desktop, place your ORIGINAL 3.1 or 3.2 CD in your reader (hold down the shift key so it does not auto start). Open the folder on your desktop and select the install version (not the upgrade). The program will go to the CD and verify it is "original", and will start to install. Then you need to enter your lisc key (same key as for the original).
          It is not suppose to work for v3.0 - but I used a 3.2 CD and their 3.0 key - and it worked. Your milage may vary.
