SHARP AR-5015 error code F5
  • Naveed Shahid
    • May 2008
    • 162
    Hello Every One ,
    I am facing a problem I have an error code F5 on my Sharp Copier and cannot clear it. Any thoughts would be appreciated.
    THANKS
  • bilyahn
    • Dec 2006
    • 1470
    Looks like a copy lamp error. Does the lamp light up when you turn it on? Test with sim 5-3. Got this from a AR5516 SM but should be the same!!
    Good luck.
    Bil
    • montana
      • Aug 2008
      • 393
      F5 00 Content Copy lamp lighting error
      Detail Copy lamp does not light despite the
      output of lighting signal.
      Copy lamp lights without the output of
      lighting signal.
      Cause DC power supply defective
      Control PWB defective
      Copy lamp defective
      Improper connection of harness between
      PCU PWB, DC power supply unit and copy
      lamp unit
      Check
      and
      remedy
      Check copy lamp for lighting with SIM5-3.
      Check harnesses and connectors between
      PCU PWB, DC power supply and copy
      lamp unit
