MXM283N - Unix printing
+ More Options
Posts
  • glewisme
    • Nov 2009
    • 240
    Hey all,I've got a customer whos inventory and sales software is unix based,I know Sharp offers the basic driver but I can't seem to find any setup instructions-guides anywhere for this.The customers software company are being asses about installing this printer beacause they bought a MXM283N from us instead of a Lexmark printer.Any help or ideas where to look.Thanks Very Much!
  • bilyahn
    • Dec 2006
    • 1470
    I am finding this file D3-PPD-1.2-100806-LINUX.zip. is that what you have? Has some different files and folders but nothing specific to install that I could find.
    • glewisme
      • Nov 2009
      • 240
      Yeah I downloaded that but it doesn't prompt you through the setup like a normal driver.I sent the file to the customer to have thier people try it.To tell you the truth I can say they just don't want to do it.Another location of the customers is already setup for this all they'd have to do is replicate it.It boils down to them being wineasses!!!!
      • bilyahn
        • Dec 2006
        • 1470
        I understand that. We have a couple of local businesses like that. Won't buy our product because their IT dept are used to Canon or whatever and don't want to take the time and effort to change over even though we offer full installation support and the whole 9 yards. Disappointing as we are the local company and the one they like is 150 miles away and costs them more in intial costs and maintenance. Go figure!
        • glewisme
          • Nov 2009
          • 240
          Tell me about it,I just got a call from our customers home office.The dumbasses just deleted the one that was working.Now they said we'll fix it but we need to charge you.What crooks they're paid to support them on their server,as well as their software,now they're adding this BS on.
          • DavePo
            • Jul 2008
            • 303
            Have they done the Tech Tip?
            MFP
            TT-20189
            Models:
            MX-C311/MX-C401/MX-B401
            MX-2300N/MX-2600N/MX-2700N/MX-3100N
            MX-3500N/MX-3501N/MX-4100N/MX-4101N/MX-4501N/MX-5001N
            MX-5500N/MX-6200N/MX-6201N/MX-7000N/MX-7001N
            MX-283N/MX-363N/MX-453N/MX-503N
            MX-M350N/MX-M450N/MX-M550N/MX-M620N/MX-M700N
            MX-M850/MX-M950/MX-M1100
            Priority: Medium
            Date: August 2010
            Subject: Installing a Sharp MFP on a Linux Operating System
            Description: Modern Linux Systems can Print to the Sharp MFPs.
            Details: This document shows how to install the Sharp PPD on a Linux system for printing.
            Prerequisites:
            A Computer on the network running a Linux Operating System that supports CUPS.
            A user account with sudo or administrator privileges on the Linux System.
            A Sharp MFP with the PostScript Kit enabled on the same network as the computer.
            The Sharp Linux PPD from the Sharp Service website.
            NOTE:
            We are using Ubuntu Linux version 10.04 for this procedure; the printer installation
            procedure for most other Linux systems will be similar.
            All of the images were captured from the Linux computer as the printer was being
            installed.
            We are using the Sharp MX-C401 for the purposes of this document; the procedure will
            be the same for other Sharp MFPs.
            TECHNICAL
            TIP
            TECHNICAL TIP TT-20189
            2 OF 17
            1. Obtain the Linux PPD from the Sharp Service Website. Click the Driver Library link to begin.
            Procedure:
            3 OF 17
            2. Select the Series, MFP, and the Platform from the drop down menus.
            3. In the Platform drop down menu, select Linux. Click the Search button to find the PPD.
            4 OF 17
            4. This shows the Linux PPD has been found in the library. Click Download File to get the PPD.
            5. Click on the checkbox next to I agree and then on the View File button. Then select Save File and
            click the OK button to save the file.
            5 OF 17
            6. Open a file browser and locate the downloaded file. Linux systems usually have a Downloads folder
            where downloaded files go. If it cannot be located, check with the user for help finding the file.
            Once the file is located, right click on it and then click on Extract Here to keep all of the files in the
            same folder.
            6 OF 17
            7. The files will extract into a folder. Double click the folder to open it.
            7 OF 17
            8. This shows us a new compressed file and a text file. The text file shows the different models that
            the PPD supports. Right click on the compressed file that ends in tar.gz and select Extract Here.
            8 OF 17
            9. The extracted files are displayed in the file browser. Note that the path to the files is displayed
            above the files. This path will be needed in a moment so do not close the file browser window.
            9 OF 17
            10. Open a Terminal session. In Ubuntu Linux the Terminal is started by clicking on Applications, then
            Accessories and then Terminal. The terminal is where to type in commands for the Linux System.
            11. This is what the terminal session looks like.
            10 OF 17
            12. Type the command sudo bash and then press Enter. Type in the requested password and press
            Enter. This will allow administrator level access to the operating system so that we can run the PPD
            setup program.
            13. Change to the folder where the PPD files have been extracted to by typing cd and the path noted
            before, then press the Enter key. In our case the change directory command is:
            cd /home/rick/Downloads/MXColor-PPD-1.2-Linux/sharp-1.2-mx230to700-ps
            Once the directory change has been done, type ./setup and press Enter.
            11 OF 17
            14. The Sharp PPD Installation Wizard starts. Click the Next Button to proceed.
            15. Click in the checkbox for the Sharp Printer Drivers and then click the Next button.
            12 OF 17
            16. Click the Next button again to Confirm.
            17. Accept the License Agreement and Click the Next button.
            13 OF 17
            18. The Wizard will install the PPDs onto the system. Click the Close button to exit the Installation
            Wizard. The PPDs have been copied into the Linux file system.
            19. Type exit in the Terminal window and press Enter to exit the administrator privilege level.
            14 OF 17
            20. Now the printer can be added to the system. To start this process click on System at the very top of
            the screen, then click Administration, and then Printing. A password will be requested for this.
            21. The Printing window will open. Click the Add button to add a new printer.
            15 OF 17
            22. The New Printer dialog window will open. Make sure that the Sharp MFP is turned on and
            connected to the network. Click on the plus sign next to the Network Printer, and the system will
            find the printers on the network, this may take a moment. Select the desired Sharp MFP from the
            listing and then click the Forward button.
            23. The Linux Operating System will search for the PPD that matches the printer. Wait for this to finish.
            16 OF 17
            24. The system has found the correct PPD and associated it with the printer. The Installable Options
            can now be selected from this window. This may appear different for other MFPs that have different
            options. Select the optional equipment installed on the MFP and click on the Forward button.
            17 OF 17
            25. The printer can be given a Name, Description, and Location. This can be left at the default if there
            is only one printer of this model number on the network. Click the Apply button to save the
            information and to move on.
            26. Click the Yes button to print a test page.
            27. Verify that the test page printed. This procedure is complete.
            • glewisme
              • Nov 2009
              • 240
              Yeah ,I saw all those,will that work with unix.Because the images they showed look nothing like the customers operating system.This software is like 9 or 10 years old?
              • glewisme
                • Nov 2009
                • 240
                Hey all I got it. We used the PCL6 drivers just had to change the PCL settings to allow CR/LF.All is well now.
                • bilyahn
                  • Dec 2006
                  • 1470
                  That's a cool trick! Have to remember that.
