Good afternoon colleagues.
Copier AR-M451N. With the established set of safety data AR-FR21.
Network worked fine. After installing a set of network scanning MX-NSX1 missing IP address!.
On the console machine put the IP address 192.168.1.230 netmask 255.255.255.0
In the worksheet, there is no IP configuration! Subnet mask is also not, DNS is also not, DHCP is turned off.
ping 192.168.1.230 address gives an error. But when connecting to a PC or Switch connection is established. Computer says that the network cable is plugged in and at 100 Mb.sek.
The printer driver found on the network device can not.
NIC rebooted several times. Did not help. It is possible that AR-FR21 blocked the network connection?
Please help me.
Please help me.
