Sharp MX2600: Cannot Print Out from Excel
+ More Options
Posts
  • Jason210
    • Jun 2010
    • 26
    We can't print out Excel 2007 (.xlsx) files on the Sharp MX2600 using postscript drivers. We have to make the Excel into a PDF and then print it out as a workaround.
    I've checked the Print area and paper szie and it looks ok.
    Any ideas?
  • OMD-227
    There should be no problems with that.
    What is happening on the machine? What is happening on the print spooler?
    • Dustin(WOP)
      • 223
      I have had, what sounds like, the similar issue many times. Make sure that Office 2007 is up to date. If I remember right there is a service pack 2 that came out some time ago that solved alot of printing issues within office, expecually excel. Hope this helps!!
      • OMD-227
        Yes, I have just done abit of research on this, and there are tonnes of info on excel printing problems in office 2007, across all brands of MFP's.
        Good one Dustin! +1R
        • mojorolla
          The Wolf
          • 2583
          We work on another manufacturers unit and a .xlsx or .docx will reboot the entire machine. I did not believe it until I actually saw it happen.
          • glewisme
            • Nov 2009
            • 240
            What is it with Office 2007,just left a customer trying to print from Word to the bypass tray set everthing correctly stii lpull from tray 1.So I go into Word's advanced settings set the default setting for that document to the bypass and still will pull from tray 1.Everything else prints fine to the bypass. F@#$in Word 2007.
