Update to update: AR 407
+ More Options
Posts
  • ITbyaccident
    • Sep 2007
    • 24
    Update to update:
    I worked around the problem by picking LPR instead of RAW for the port. It works great now. Still, if anyone has a suggestion about the stupid password, I would love to hear it.
  • bilyahn
    • Dec 2006
    • 1470
    Is it the job control function that you are talking about in printing preferences or something else? If there is a password problem you can go into key ops and enable changes to the printer settings then restore to factory defaults and also reset the NIC. Will not erase the passwords until you do that!!
    Good luck!
    • ITbyaccident
      • Sep 2007
      • 24
      Thanks, Bilyahn. That's exactly how I ended up getting past the problem. Thanks for the reply.
