sharp AR 502 copier shuts off
  • tmaze01
    • Oct 2010
    • 76
    [Electrical] sharp AR 502 copier shuts off
    Hello,
    I have sharp ar 502 copier that shuts down.(just like if it was off,except pwr switch is in on position) to get it to copy i turn switch to off and back to on, after making copies and its just waiting/in ready mode does the same thing.I was thinking power supply or drive board.
    Has anyone seen this problem before?
    As always any help is greatly appreciated,
    THANK YOU IN ADVANCE....
    Taylor
  • ZOOTECH
    Senior member of CRS
    • 3375
    Check for cold solder on the power transistors in the DC power supply.
    • tmaze01
      • Oct 2010
      • 76
      will do, thanks so much for your help..
      • OMD-227
        Zootech is right as usual.
        I saw the same thing myself many years ago. Had to see the poor solder joint to believe it, but it fixed the problem. Was an AR337 in my uncles office.
        I'd always heard about this problem/fix, but that was the only time I was ever involved with this particular symptom.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
          Paul@justmanuals.com
          • tmaze01
            • Oct 2010
            • 76
            i appreciate your help
            • tmaze01
              • Oct 2010
              • 76
