F1-10 Error on MX2700n
+ More Options
Posts
  • Highwood
    I have an mx2700 with the fnx1 finisher that goes into the f1-10 error as soon as the macine boots up.
    The stapler unit and finisher control board have both been changed but that has not fixed the problem.
  • choicecopyguy
    • Mar 2006
    • 111
    Since you have replaced stapler and finsher control I would dbl check all harnesses and connections, after that, I think its the PCU next. Have you talked with Sharp about it?
    • gherkin
      check the harness from the finisher pwb to the stable unit, it might have stretched or kinked,
      • fajdooo
        Check the wiring betven the PCB board and the stapler.
