sharp ar 507
  • tmaze01
    • Oct 2010
    • 76
    [Electrical] sharp ar 507
    Hello there,
    i recently posted a question (it was under ar 502 and it was shutting off on its own)
    well it is a ar507 the problem is that originally the call was for Lcc (3000) it lifted past
    the height allowed by limit sensor and it tweaked the plate and snapped the lift cable
    the customer was able to buy a new one in box/ now when i plug the lcc in it detects it but says it is out of service and when i press the button no led or power. My question is is it possible that when the old lcc went down it damaged the control board or ???
    AS ALWAYS YOUR HELP IS APPRECIATED
    THANKS
    TAYLOR
  • ZOOTECH
    Senior member of CRS
    • 3374
    If you had a LCC tray problem, you must clear the code with TC 15.
    • tmaze01
      • Oct 2010
      • 76
      sharp 507
      hi paul thanks for replying i am trying to reply to your message it keeps telling me i dont have permission or not logged in (so are probably gonna recieve 3 or 4 replies regarding this post from ) ok are u refering to svc mode then code 15 sub 0 to clear the u4?
      also i only arrived after the problem and the machine was DEAD and LCC was detached an set aside.
      thanks again
      taylor
      • ZOOTECH
        • 3374
        Sorry, I didn't see the reference to a U4 code; that relates to the Alignment plate or rear plate of the duplex unit. TC (svc mode) 14 should clear the code, and the plates can be tested and checked with TC 9.
        • tmaze01
          • Oct 2010
          • 76
          ok, i am talking about the LCT (3000) i noticed your referencing the duplex instead
          • ZOOTECH
            • 3374
            thanks again
            taylor
            Again, I'm sorry, but you mentioned the u4 code which refers to the duplex unit. For LCC tray problems it is TC 15 (svc mode).
            • tmaze01
              • Oct 2010
              • 76
              hey paul
              sorry my bad, i meant simulation code 15 sub 0 to reset the U 4 error code ,am i say that right??
              • ZOOTECH
                • 3374
                TC 15 resets tray error codes, not a U4 error. A U4 error relates to the duplex alignment plate or rear plate, and is cleared with TC 14.
                • tmaze01
                  • Oct 2010
                  • 76
                  thank you very much i appreciate your help
                  taylor
