h5-01 error code for sharp arm550n
  • Dark Helmet
    • May 2009
    • 853
    #16
    Ok last one!
    Hit custom settings. On the touch screen hit key operators. The password should be 00000
    If the password is changed use Sim 22-7 to find out the code.
    Inside the key ops menu go to network settings. I think it's on page 2. From there you can enable DHCP or set a static IP.
    • OMD-227
      #17
      AAAhhhhhh... sorry.... I gave wrong machine system settings login.
      Lawrence is right again........ 00000.
      Sorry bro.
      • Juzam
        • 12
        #18
        if i scan something how do i save it to the printer and then how do i retreive it from the printer on another computer?
        • Juzam
          • 12
          #19
          new error ce-02
          • bonnie750
            • 302
            #20
            Get a tech mate!
            • CBMWilson
              • Sep 2010
              • 53
              #21
              CE-02 is a network communication error
              in custom settings - network settings check that the IP address and subnet is correct
              A small local network should have 255.255.255.0 as the subnet mask
              • OMD-227
                #22
                Good advice...... get a tech.
                But.... check if you have the network scan option installed (NSX1 kit) in 22-10.
                • Juzam
                  • 12
                  #23
                  i have a nscn ar something i noticed the printer has a website how do set the printer to make pdf files when scanning documents onto the hd?
                  • Juzam
                    • 12
                    #24
                    when i scan documents or copy documents the printer prints them out perfectly, but when i try to download them to my computer i get a black screen am i using the wrong tiff viewer? is there a way to make the printer save scans and copies as pdfs? anyone know of a good tiff viewer / converter?
                    • OMD-227
                      #25
                      Are you saying that you have scans on the HDD that you wish to view on a PC?
                      If you have the correct hardware in the copier (AR-P19 & NSX1 kits) you can do proper network scanning. You still haven't confirmed what options you have installed yet. This info will help us help you.... get it.
                      • Juzam
                        • 12
                        #26
                        well i can see the scans now and the copies, my new issue for the day is sending the files on the printer to another computer, i can get to the printer website but im getting an error when i try to send a file over, is there any port settings i need to free up?
                        • bilyahn
                          • Dec 2006
                          • 1470
                          #27
                          Move or save them to your PC then send them wherever you like.
                          • fightersblue
                            #28
                            Hi I've the same problem. Once I scan and try to save it on my pc, it turns out all black. How did you fix it? thanks.
                            • newtonn
                              #29
                              Re: h5-01 error code for sharp arm550n
                              Dear all,
                              Am new to this forum and am happy to join you guys in this forum.
                              Please i need help for my old sharp copier model SHARP AR5520 software.
                              thks all
