Sharp MX 3501n 150K maintenance
  • Cirrus
    • May 2008
    • 43
    [Misc] Sharp MX 3501n 150K maintenance
    We only have the one sharp. I have the manual and have looked at the maintenance schedule. My question would be is there a 150K kit that I can order that includes everything. Not having much luck searching.
    Thanks for your help
  • bilyahn
    • Dec 2006
    • 1470
    I'm afraid that you are out of luck on this one. They have a lot of kits with varying copy counts, these are all listed in the service manual. Unfortunately you have to buy them all separately. It can be very confusing sometimes as to what you need and don't need. Personally we always have #1,2,5 and 6 in stock and take them with us and order the others as needed.
    1 Heat roller kit Upper heat roller x 1 300K MX-450HK
    Fuser gear x 1
    Upper separation pawl x 4
    Upper separation pawl SP-N x 4
    Upper thermistor sub x 1
    Upper thermistor side x 1
    Upper thermistor CJ x 1
    Upper heat roller bearing x 2
    Lower heat roller x 1
    Lower heat roller bearing x 2
    Lower separation pawl/spring x 4
    Lower thermistor x 1
    2 Primary transfer kit Intermediate transfer belt x 1 150K MX-450Y1
    Primary transfer blade x 1
    Primary transfer conductive collar x 4
    PS paper dust removal cleaner x 1
    Bearing x 4
    3 Secondary transfer kit Secondary transfer belt x 1 300K MX-450Y2
    Secondary transfer roller x 1
    Secondary transfer idle gear x 1
    Primary transfer roller x 4
    Belt drive gear x 1
    4 Filter kit Ozone filter x 1 150K MX-450FL For North America/South
    Paper exit filter x 2 and Central America
    Ozone filter x 1 150K MX-270FLN For Asia/Agencies
    5 Web cleaning kit Web unit x 1 150K MX-450WC
    Sub roller x 1
    Sub roller bearing x 2
    6 Waste toner box kit Waste toner box unit (with LSU cleaner x 3) x 1 40K MX-270HB Each color 5% coverage,
    color ratios 43%
    7 DV seal kit DV seal x 3 Black: 150K,
    Color: 100K
    MX-270DS
    DV side seal F/R x 3
    Toner filter x 3
    8 Main charger kit Main charger unit x 1 Black: 150K,
    Color: 100K
    MX-270MK
    Good luck.
    Bil
    • OMD-227
      Bil has given some great info for you there, but it depends also on if its the machine's first 150K service.
      At the very first 150K, 99% of the time you'll only need the K drum unit or kit and the web unit or kit. Everything else normally due at 150K (like primary belt unit & K dev) can simply be reset and run a color calibration afterwards. The machine will work great. Everything that was reset usually gets through to the 300K service no problems.
      If this is a picky client or is color critical, then replace everything that is due listed above.
