MX31000N copy issues
  • Dustin(WOP)
    • 223
    Hello fellow techs
    I have a weird one on my hands. If you print a document it looks fine, however when you go to make a copy of that print out the desity gives out/ isn't as crisp.
    I will attach an image so you can see what I mean. I have callibrated the machine 3 times in the last 3 weeks and hasn't seemed to help a whole lot. Any help is greatly appreciated!!! thanks!!
  • johnbla
    • Apr 2005
    • 94
    Dustin
    What was the Dpi of the original print ?
    What was the exposure setting... 'Copy of Copy' or 'Auto' ?
    The Sharp Mx31 range are like any other 'Copier' of it's class,..... Any Copy is only 90% (or less) as good as the original.
    The original image will always depreciate when being 'copied'.
    I would check the Dpi of the original and look at the 'default' settings of the machine.
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
    • OMD-227
      John is right.
      With the Pastel2's & C-Jupiter2's, you need to change the exposure mode to anything other than auto. What you are seeing Dustin is a classic example of the default setting/output from these machines on auto exposure mode. No amount of calibration will fix this. You need to put it in Text or Text/Photo mode for this to copy alot better. I have the documentation here explaining this somewhere, which I'll track down. I have got several clients running text mode as their default as the output is alot better and they prefer that as their default setting.
      • Dustin(WOP)
        • 223
        Thanks for the information guys, I appreciate it! Wazza if you could track down the information and send it to me that would be awesome, I have never seen any information on the exposure setting. thanks!!
