Sharp Fax Model AR-FX12
  • Tech2002
    • Aug 2008
    • 334
    I have a customer that when they send Faxes at the receiving end they are coming out either speckled or there is a band in the middle of the page where there should be print but is none.
    The Copy/Print side of things I am told are good.
    Anyone ever see this before? Any suggestions?
    Thanks.
  • OMD-227
    Check the Image send default resolution settings & still clean all the optics/mirrors. Its common for copy to be clean, but poor quality scan for image send or vice-versa, as the scanner is setup differently for each mode.
    • Tech2002
      • Aug 2008
      • 334
      Appreciate the tip - I think I may have been looking too deep. That just may be the problem. I'll let you know the outcome.
      Thank you.
