sharf AR235 usb printing
  • technician
    • Aug 2010
    • 25
    Hello Every body
    I request to all technical Engineer.
    Problem in the sharp AR235 printing???
    sharp AR 235 has a lpt printing option.
    but in the computer of customer no lpt port.
    so i connect the machine with interface connector of lpt and usb.
    so when i connect the machine it detect auto port and ask me the usb driver but i dont have usb driver.
    I have only lpt
    soo what can i do in such situation
    please give me some tips
    I am waiting for your kind informatiom
    thanks to all
  • OMD-227
    Dont think USB is supported mate. Its not an optional item. Standard Parallel or optional Network.
    There is a generic PCL driver for that series of machine you could try if you had a USB to Parallel converter.
    • TennWalker
      • Apr 2007
      • 72
      I have also had some success with the Pricom 3100 Parallel to Ethernet converter. This was offered by Sharp to give a cheaper alternative to the full network option, provided the customer did not want scanning. The only problem that I have had intermittently on some workstations was that I had to physically connect the parallel cable to the computer (which you say you do not have) to complete the driver installation, after the required reboot to finish the driver installation. I experienced this on one XP workstation. All of my other installs have gone well by installing the Pricom Port Driver. I also use the "Add Printer" option to manually install the printer, not the fully automated version which requires the reboot to finish the driver install.
      I hope this helps a little.
      I thought I was getting wiser as time went on... I now realize I am just getting older.
      • technician
        • Aug 2010
        • 25
        sir i buy usb to parallel converter now.
        and install pcl6 driver but the machine did not print.
        do u tell me the which port i select??
        usb virtual port??
        lpt port or com port??
        i am waiting for your reply
        thanks
        • bilyahn
          • Dec 2006
          • 1470
          If you are using the PCL6 driver executable program it will not work the way you are trying to do it. I have used a generic print driver (HP LJ4000) with the parallel port but you do not get full functionality with this just the ability to print 8-1/2 x 11 or A4.
          Good luck.
          Bil
          • TennWalker
            • Apr 2007
            • 72
            I would try what Bilyahn is suggesting. I have not had any success with the USB to Parallel Adapter myself. The Silex Pricom 3100 was the only thing that worked for me.
            Take care
