Gotta be sensors. As I said earlier, F1-19 & F1-20 has always been either the sensor, spring or sluggish sensor arm causing those codes.
MX-FNX1 Stapling Issue
OMD-227
I finally change out the Spring, Sensor, and Sensor Arm. I still come up with the F1-20 Code. I took things apart, checked all connections. When I did this I got the Stapler to work - the only thng was it was stapling, running staples, but it wasn't stapling the paper. Then I took things apart again, and ran the stapler. I got the F1-20 code then I got a F1-08 Code. I checked the voltage as suggested - all showed okay. I'm missing something here, probably something simple, but can't seem to get my hands on the issue. That's my update on things.Comment
