Does anyone know how to run 24-01 on this machine. I tried yesterday to clear the jam and trouble counts and got as far as selecting which one to delete and then nothing else the book said to do worked. This is the only one of these oddballs we have, (the rest are mxc machines). Any help would be great.
Dxc400 can't run 24-01
That's the problem. The screen on the DX isn't a touch screen and the way you select it is to enter the number of the item you want to clear then use the arrow keys to select execute then hit OK button. That's what the book says anyway, but it doesn't work.I know I should be ashamed of myself. Strangely though, I am not.Comment
OMD-227
Like the MXC310 & MXC380 (4.3 inch non-touch screen), when using the service modes, you need to also use the OSA select key (which is the one that looks like a backwards arrow... above system settings key).
Its abit confusing, but using the usual cross-bar button as well as the OSA select key & 'OK' key to enter the menus is the way that its done.Comment
Thanks, I'll try that next time I'm there. Do you have an actual procedure you could send me? There isn't any mention of any of that in the service manual. It just says select counter to be cleared, press execute and yes, just like the other machines that do have a touch screen.
ThanksI know I should be ashamed of myself. Strangely though, I am not.Comment
OMD-227
Page 111 of the MXC Serv Manual (basic operation of simulation).
You'll see its says to select the item with the cross key and then OSA key. You then use the cross key to move across the screen to select execute & yes by using the OK button.Comment
OMD-227
