MX-M453, spf jam
  • frevl
    • Jun 2010
    • 8
    [Jamming] MX-M453, spf jam
    Hi all,
    The rspf from a mx-m453 jams (fax+scan)
    when using it in copy mode it's working fine.
    Scanning A4R is also no problem, i think it's timing releated,
    The data list reporting a jam at sppd2.
    i didn't find a solution in the technical reports,
    Someone already encounterde this problem?
    merry christmas.
    Fre.
  • OMD-227
    If the jam code is SPPD2_N, the problem has been noted to be associated with SPPD1 actuator being sluggish to return.
    Add an extra tension turn to the SPPD1 spring.
    This doesnt explain why its working fine in copy mode, but there have been known issues with SPPD1 spring tension causing SPPD2_N jams, so check it out anyway.
