Sharp AR-m350N
  • johnboyd
    Sharp AR-m350N
    I am working on a Ar-m350 it keeps freezing up about once a day. When it happens the screen goes blank and won\'t function at all.
    1. I replaceced every rom chip
    2. replaced the main board / Print board / image process board
    3. checked all harnesses and connectors
    3. checked drum / dv, and all related hv connectors
    4. checked transfer roller and contacts.
    5. checked laser and all related connectors
    This is a Weird one! If anyone has any ideas please pass them along, i would really appreciate it.
    Thank\'s
  • Jerry
    Re:Sharp AR-m350N
    I have replaced 2 opp panels with this same problem, have you replaced the opp panel? Check the ribbon cable that plugs into the opp panel, sometimes the cable holders will brake not holding the cable tight. Roll up a small piece of paper and place behind ribbon cable. Have seen the fax units lock up the opp panel also. Have you tried unplugging all options? Good luck, let us know if you find fix.
    • Jerry
      Re:Sharp AR-m350N
      • johnboyd
        Re:Sharp AR-m350N
        Thank\'s for the reply jerry! I have not tried that, but i will get right on it. Thank\'s again..........John
        • johnboyd
          Re:Sharp AR-m350N
          Hi Jerry,
          So Far your suggestion seems to have taken care of the problem.
          Now all i have to do is find a Solution to a Unix related Network issue, but i think i already have a solution for that. Thank\'s again
          ..............................John
          • Jerry
            Re:Sharp AR-m350N
            That\'s cool John! Congrats
