SHARP AF-7855
  • gitana1983
    • Mar 2009
    • 141
    SHARP AF-7855
    Ok.. this is an oooooollllddddddd Sharp, the SF7855 and it has a U-1 code which is related to the battery, does anybody knows the part number for that battery???
  • ZOOTECH
    Senior member of CRS
    • 3375
    My EPG doesn't show the parts for the Main PWB, but the SF7900 battery is p/n UBATL0008FCZZ (it should be the same). If the battery reads more than 3.3v, it probably is ok - I believe there was a bulletin about a high voltage lead that could cause a U1 and other codes.
    • vlad_
      • Jul 2008
      • 98
      Yes. Was like a printed bilyuten, SF-7800/7850 which spoke of the breakdown of high voltage with MC on the grid, the result was U2 or even hieroglyphics instead of letters and numbers. When U1 change batteries. There were problems with the comparator. No longer remember.
      • lky1978
        • Mar 2009
        • 483
        u can get the replacement battery model cr-2032, of coz u need to solder it.
        • CT Copier Repair
          • Mar 2010
          • 304
          Now i feel old
          i have done those
