AR-M350 Locks up...HELP Please
  • Buddy
    • Aug 2009
    • 285
    I've never seen this. After turning the copier on, I'm able to make one change on the touch screen. I tried to disconnect the finisher and duplex unit. I've done the touch screen adjustment, SP65. If I'm in the SP mode I can play with the keys as much as I want and they keep working (both the number keys and the touch screen). But as soon as I try to make a copy, I can only get one change on the touch screen and then it just freezes. Any ideas will be greatly appreciated.Thanks
  • mxm
    • Feb 2011
    • 37
    has some one been playing with the --Key operation setting-- hold down a key for more than 2 seconds
    system settings
    Enter Key Operator Code
    OPERATION SETTINGS
    KEY OPERATION SETTING
    These programs are used to set the length of time a
    key in the touch panel must be touched before the key
    input is registered, and to prevent repeated key input
    when a key is touched continuously.
    โ€ข Time until key input is registered
    The time can be set from 0 seconds to 2 seconds in
    increments of 0.5 seconds. Normally the time is set
    to 0 seconds so that key input is immediately
    registered when a key is touched. By lengthening the
    time setting, key input can be prevented when a key
    is touched accidentally. Keep in mind, however, that
    when a longer setting is selected more care is
    required when touching keys to ensure that key input
    is registered.
    โ€ข Prohibit key repeat
    The touch panel contains keys such as the zoom
    keys (for setting the ratio) that can be touched
    continuously to make a value change until it reaches
    a desired value.
    This feature whereby a value changes continuously
    while a key is touched is called key repeat.
    Key repeat is normally enabled. If you wish to prohibit
    key repeat, select the "DISABLE AUTO KEY
    REPEAT" checkbox.
    • Buddy
      • Aug 2009
      • 285
      Thanks mxm. Unfortunately, it didn't help. The machine works fine for anywhere between 1/2hr to an hour. It then goes back to freezing. I'm going to try another op panel tomorrow, unless you have another idea. Thanks again.
      • jward
        • Feb 2011
        • 8
        I would suspect the HDD, any E7 codes in the history?
        • Buddy
          • Aug 2009
          • 285
          Thanks guys. I should have posted the fix. It was the op panel. Thanks again.
