AR-M355 Web Interface password
  • tmanamore
    • Sep 2009
    • 74
    I have a Sharp AR-M355. I am trying to access the web interface but the previous customer changed the password. How can I default the user name & password and what would the default be?
  • bdcrandall13
    • Sep 2010
    • 235
    I'm not sure that you can without wiping the NIC. Even then I dont know if that would help.
    • bilyahn
      • Dec 2006
      • 1455
      You can reset them by resetting the NIC card under system settings, key operator settings, (00000 is default), printer settings or network settings, reset NIC. The default login: admin, password: Sharp. Be sure to check your NIC settings before you do this if it is not set up for DHCP so you will know what to re-enter in the IP settings.
      Good luck.
      Bil
      • tmanamore
        • Sep 2009
        • 74
        admin, password doesn't work. Any other suggestions.
        • tmanamore
          • Sep 2009
          • 74
          admin, sharp doesn't work. Please help.
          • ZOOTECH
            Senior member of CRS
            • 3381
            Upper case S in sharp.
            • tmanamore
              • Sep 2009
              • 74
              Thanks so much!
