having problem clearing the fax/scan log on ARM237/257/277/317
  • jward
    • Feb 2011
    • 8
    [Misc] having problem clearing the fax/scan log on ARM237/257/277/317
    Hello everyone, 1st post and new to the forum, copier tech for 3 years and general tech for over 20. This is a great site and lots of excellent information here!
    Did a search but cant find the solution...
    I am doing recons of mostly 237s and 277s and one thing I havent figured out is how to clear the [completed] fax and scan logs that a customer can see if they hit "completed" faxes or scans. I have tried sims 66-10 fax memory clear and 67-17 nvram clear but the logs remain. Can someone tell me how to delete these?
    Thanks in advance!
  • mxm
    • Feb 2011
    • 37
    secret test command 89-3 will clear key opp code/data clear(inc fax)
    this is on a uk equivalent machine this mite work give it a go just don't clear 89-1 all counters
    • jward
      • Feb 2011
      • 8
      Just tried that, no results. the log still shows when you press "Job status" > "Complete" > "scans/ftp".
      appreciate the reply though!
      • mxm
        • Feb 2011
        • 37
        is there a tc 62-10 on the older machines
        • jward
          • Feb 2011
          • 8
          There is no 62-10 on this one...
          • jward
            • Feb 2011
            • 8
            Re: having problem clearing the fax/scan log on ARM237/257/277/317
            bumping up - still no solution for clearing the scan logs. looking for more ideas.... anybody?
            • bilyahn
              • Dec 2006
              • 1470
              Have you tried accessing the web page and looking at/for the job log? On the newer series you can save/delete the job log from there. Not sure if you can do it on this model or not.
              Good luck.
              Bil
              • Sam Tofu
                • Dec 2007
                • 130
                If they have NIC- browser into IP. For the admin access the user and pass is
                "Sharp" and "admin" I forget which is user and which is pass. That should allow
                Sim 66-10 is image data memory clear
                • Sam Tofu
                  • Dec 2007
                  • 130
                  Here is detail image of the Sim 66-10
