Sharp Ar-NC5J
  • cucuklotz
    • Mar 2007
    • 611
    Sharp Ar-NC5J
    Hi,
    Anyone have one in working condition(new or used) + access that would allow me to set it up for customer (being able to get Key from sharp). Easy to set up but need to go through Sharp for License Code.
    Thanks Andy
  • bilyahn
    • Dec 2006
    • 1467
    What machine are you trying to get this for? Normally there are a couple of ROMs that go with this if it is not already an "N" version machine.
    Bil
    • cucuklotz
      • Mar 2007
      • 611
      HI Bil,
      Thanks for reply. It is the AR m237. It has print board on it but not for network I was told,
      Thanks Andy
      • bilyahn
        • Dec 2006
        • 1467
        The unit comes with a board that allows you to print using a USB device cable. In order to network print you will need to get the ARP17 print controller kit which comes with a different board (you replace the existing board) that has the NIC installed on the board. You can always share the device from a computer that you have connected to it by USB as an alternative.
        Good luck.
        Bil
        • cucuklotz
          • Mar 2007
          • 611
          HI,
          Thanks for reply and help.
          ANDY
          • bilyahn
            • Dec 2006
            • 1467
            You're welcome.
            • keleema
              Do you still need a network kit?, I may be able to help.
              Regards Lee
              • cucuklotz
                • Mar 2007
                • 611
                Hi,
                Thanks for response.How much can I can one for(used is fine) so I can quote customer.
                thanks Andy
