MX-M363N Rotation Lights
  • otuvak
    • Aug 2010
    • 102
    Is there a way to shut off rotation lights for the drums in this paticular model? Maint light is coming on before 200k on the drum..Thanks everyone!
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    If there's no issue with copy quality, I would either recommend ignoring it or changing the maintenance cycle to put the warning indicator at the full 200k
    • mojorolla
      The Wolf
      • 2627
      SIM 55-1, Set switch 9, bit 8 to 1. This will base the maintenance on page count instead of drum rotation. You will also get a longer life with this setting.
      • otuvak
        • Aug 2010
        • 102
        Thanks for the help. I knew that setting but bulletin that I had talks about that just for color machines. I will change it thanks again!
