MX4500 Adjusting Print Quality - Please wait
  • hammer
    • May 2008
    • 111
    Hi Guys, we have an MX4500 that keeps saying "Adjusting Print Quality - Please Wait". We have changed the drums and developers and re-calibrated using the SIT chart. We have installed the latest driver and disabled the Bit Switch that allows this message to appear. Does anyone have any suggestions?
  • RascalMJ
    • Mar 2009
    • 174
    TT-13856
    Models:
    MX-2300N / 2600N / 2700N / 3100N / 3500N / 3501N / 4501N /
    5500N / 6200N / 6201N / 7000N / 70001N
    Priority Medium
    Date: August 2008
    Subject: Display message: 'Please Wait, Print Quality is Being Automatically
    Adjusted.
    Symptom: Display message: 'Please Wait, Print Quality is Being Automatically Adjusted.'
    (Adjustment of Execution Timing of Process Control)
    Cause: . When Process Control is performed, the display will read Please Wait, Print Quality is
    Being Automatically Adjusted. A delay will occur while process control is adjusted.
    Solution: For optimum copy quality, it is strongly recommended to leave the process control
    intervals set to factory default levels. In some cases, a customer may complain that
    these messages occur too frequently. In this case, it is possible to adjust the process
    control intervals, however, the customer must be made aware that a noticeable
    reduction in copy quality may occur.
    Process Control adjustment occurs at power on, then repeats at certain intervals based
    on drum rotation.
    Refer to detail of Simulation 44-28 in the Service Manual. Confirm that all settings are
    at factory default.
    To increase the interval between execution of the process control correction, do the
    following:
    For MX-2300/2700:
    Value K: BK_RATIO, default value is 20, set to 40.
    Value L: M_RATIO, default value is 20, set to 40.
    For MX-3501/4501:
    Value L: BK_RATIO, default value is 20, set to 40.
    Value M: M_RATIO, default value is 20, set to 40.
    Important Note: Increasing the interval can reduce image quality, and it is not
    recommended to change any simulation 44-28 settings other than as covered
    previously.
    • bdcrandall13
      • Sep 2010
      • 236
      Updating to the latest firmware version will greatly improve the wait times as well.
